e reader not charging via laptop
profile.country.en_GB.title
joabeck51
Besucher
My sony e reader PRS 600 is refusing to charge via usb and laptop - normally this works perfectly well.
Any ideas?
4 ANTWORTEN 4
SteveF48
Neues Mitglied
Do you have another usb cable you could use?
singoutoftune
Besucher
I reset mine,pressing the reset button,seemed ok after that.
specialist-convergence
Besucher
Make sure you laptop is not in a power save mode, as this will lower the output on connections, and may not be enough to kick that charging on the Reader.
davwood75
Besucher
I had the same problem when my PRS600 would not charge from a PC - I went into 'settings' on the reader and reset default settings,essentially logging on again an hey presto,plugged it in again and charged up as normal
