Podziel się wrażeniami!
My EReader PRS-600 has stopped being recognised by my laptop and is showing problem code 43. I have tried it with another computer with the same result. It has worked OK for about a year and has only just started causing a problem is there anything I can do?
I don't know the 600, but presumably it has a re-set facility, hard or soft ?
Someone out there might know what a 43 is.
U sual practice is try a soft reset if it has this.
Hard reset's usually mean you lose everything on the device.
You have run a-v ?
dafrank - don't know if this helps, but this is the M/soft description of the code :
http://technet.microsoft.com/en-us/l...8WS.10%29.aspx
Hope it helps - definitely outside my limited tech-knowledge I'm afraid.
Sorry - forgot.
Read this (lengthy! ) thread, too.
It is in lower left panel on your thread page...
Hi thanks for the link I'll give it a try.
mein ebook reader prs-t2 zeigt den Fehlercode 43 an, was kann ich tun
