What's Happened to My DAB Signal?
profile.country.en_GB.title
The_navigator
I can't get any DAB signal on my XDR-DS12iP docking system. The screen shows it is selecting the required station but there is no audio and the tuner does not work. The FM channels and iPod playback work fine.
My wife thinks she "may have pressed something" when switching the set on but I can't find anything that brings back DAB. Has anybody any ideas?
2 REPLIES 2
Did you get this problem sorted since June? My DAB is fussy about where it's positioned. This is because DAB is on a much higher radio frequency than FM. I positioned my DAB radio on the windowsill, which seems to work, with 3 bars on the S-Meter. If that fails, Google it!
phalos
My power supply failed years ago and I would like to resurrect my XDR-DS12iP again wonder if anyone found a solution as Sony was most unhelpul at the time. Or does anyone know the power rating so I might match a similar 8V power supply with or w/o an extra resistor
