- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi guys,
I'm having issues accessing a particular web service since firmware update - BBC iPlayer.
Netflix still works fine.
Can access iPlayer but when I try to begin a stream having selected a program, the following display shows:
SSL Alarm Display
The security of the target peg cannot be confirmed. An error has occurred during server authentication
I've tried manually setting the IP of the player, and connected succesfully but that didn't solve the issue. I've also tried a reset of internet and network settings and reinput the wireless details etc... still no joy.
Does anybody have any advice - and if not, is it possible to roll back to the last firmware version? Seems like Sony has just broken my Bluray player
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Would like to know from sony what the cause is, but happy that it is working.
Thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just to add - my firmware version is currently: M11.R.0493
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Did you ever find a solution to this please? I'm in exactly the same position and not very happy!
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I too am getting this, has anyone found a solution yet, I can use lovefilm perfectly but iPlayer keeps giving this message. I have tried using both wireless and direct ethernet connection and get the same. My sky box has no trouble connecting to bbc iplayer and downloading, my pc also connects to the bbc and streams ok, so looks like my router settings are all working ok.
Nick
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi all
Has anyone tried a factory reset of your bluray player? I know the orignial poster said that they have reset network settings, but a factory reset may flush things out?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yep - it's worked for me. Had tried resetting network settings to no avail, but factory reset has cured it. iPlayer now working again at last!:smileyhappy:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have exactly the same problem with a BDP-S1100, however it is not cured by a Factory Reset.
Does anyone have a solution?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Factory reset twice and network reset twice, re setup network and now i player working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
