Dolby 5.1 from UHP-H1?
OPGELOST
PaulRC
Nieuw
In have Apple TV, SKY and a UHP-H1 all connected to my Bravia TV via HDMI. The TV connects to a Sonos Soundbar via optical cable. I get Dolby 5.1 surround from SKY and Apple devices but can only get Stereo from the UHP-H1?
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
PaulRC
Nieuw
Hi Manolo, thanks for your reply. It turns out that one of the HDMI inputs on my Bravia was down-converting the 5.1 output to stereo - the other 2 inputs were fine. I could find no information on this in the Sony user guide for my TV. The test was simple in the end - when I connected the optical output from the UHP-H1 to the Sonos playbar directly, 5.1 appeared in the Sonos diagnostic menu. The sound difference is incredible. You live and you learn. Cheers, Paul
Bekijk de oplossing in de community in het oorspronkelijke bericht
3 ANTWOORDEN 3
Marino.Manolo
can you verify in [Audio Settings]:
[Digital Audio Output] > PCM[BD Audio MIX Setting] > Off[DTS Neo:6] > Off and [Downmix][Surround].
Manolo
PaulRC
Nieuw
Marino.Manolo
:wink:
Manolo
