How To: Set-up your new BRAVIA TV
158,594  Views
Join us as we follow the step-by-step process of setting up a Sony BRAVIA TV. Learn how to select a wireless network and how to scan for channels so you can enjoy all aspects of your new TV.
 Note: When asked to choose between Antenna or Cable to tune Freeview TV channels, for most people, you should choose Antenna (as your Freeview signal is coming from the aerial on your roof or loft)
33 Comments
8jeffhowe
I am trying to confirm that my Television Bravia KDLEX403 9110471 and my Hard Disk Recorder SVR HDT500 S/N 1016137 are both registered so that I update my network to a wireless system. I purchased the Television in 2010 and the recorder in 2011
clarkrfm
I bought the 49X8505B to show photographs on the Lightroom App on my iMac 27 incn with retina.
I expected to use Apple TV but the iMac doesn't seem to have the mirror option. Unless you can tell me otherwise ... thanks Roger
jakjames1
How do i get chromecast on my bravia kdl43w755c
toppergraph
has anyone found a good working method to connect a keyboard and mouse?
I wonder why you sent me a link to see a video about how to connect my Sony Bravia to Internet since my model (KDL-40EX600) cannot be connected to Internet. Maybe you should check the model number before sending emails.
pinxton20
Recently bought (Nov 2015) Sony Bravia 43" 4K TV.  Trying to set up favourites.  Major update for Youview when I switched on, but I did not implement Youview, because I don't want it, and I don't want to lose the other facilities.  Although I can and programs to favourites, I can't select Favourites from the guide (it shows all channels).  How can I select favourites on the guide?
OBONEJB
I have been trying to register my sony bravia KDL 42w653a with SEN so I can watch amazon video. But i get the registration code from the tv and the activation link won't accept it.
kdl26v4000
I have been trying to connect my KDL32W653A to get Amazon video too. Currently tried 7 different codes all deemed incorrect, try again. After two attempts support sent email with instructions which got me pack to the page that I had been using all along. At midday today they said they would sort it out and call back in half an hour, it is 6.30 now and no one has called back. It has all been a painful waste of time. It connects to Netflix etc no problem. All extremely frustrating for something that should be so simple.
ArferDaley
can you connect the Sony Bravia KDL43W809CBU  to freeview and a sattelite dish for freesat
ericharrison
The Sky engineer is having problems connecting Sky to my Bravia KD49X8305C - is a code number necessary?
soleyman.rahmani
Dear All
Does anybody knows why KDL-50W805C wifi is not working properly?
It is connected through wifi just for the first time for a few minutes then it has been gone and no access to the network!!!
Also the same situation happened for screen mirror it was connected for a few minutes then screen has freezed!! and no more mirroring.
It works via LAN connection.
Waiting for your help.
Thank you
Cosmo16
My KDL-40RD453 keeps on displaying cable OK Internet connection failed. I have tested the connection with my laptop (Wifi switced off) and it works perfectly. I have tried updating the firmware. That looks as if it was already up to date. I have seen references to returning to factory settings how is this done. I don't want to have to return my TV.
Hopcraft12
Could you please send the complete manual of my 4K 43 just bought it from curry's last week, my Son bought it for our Christmas present.
He payed £45 for an engineeer to install and give a demonstration, we are both 70years old.
He installed it turn it on then said it's all in the book.
Welll it's not all in the book Curry's supplied only the remote information we phoned Curry's to say how disgusted we were at the demonstration.
That is why I need the full Manual to read myself.
Please send to my registered address as my Husband dose not use the internet!!!
yours truly
Mrs Shirley Stevens
Tricky1977
Can someone help me.  I have a Samsung S7 Edge and am trying to Mirror Link to my Sony TV.  I can pair it up  but all I get is a blank screen.  I can hear the sound but no picture.   Any ideas??? Thanks
ArferDaley
as i remember it will be down to your file type but i could be wrong when i cast from windows 7 it wont play all files and the same with w 10 ive started encoding all my files to MP4 and all seems to be jogin along nicely
Djhodgson
Can anyone please tell me which code to input into my Sky remote so that it will operate my Bravia KD-55XD9305. It is not listed in the Remote set up list of Sony TVs.
Not applicable
TO EVERYONE :
If you are having problems or in need of advice, please create a "New Topic" in the appropriate category on the main forums:
https://community.sony.co.uk/t5/english-community/ct-p/en
Thank you.
plop81
Buongiorno, dall'app OPERA vorrei vedere film o serie tv indiane.con sottotitoli in italiano. Dal canale YUUTP posso impostare come lingua dei sottotitoli solo quelle indiane o inglese. Esiste un app che mi permette di inserire la.lingua dei sottotitoli in italiano?
Grazie
Sumaira.fa
I bought sony KD65XE8596 with sony sound bar, Can you please tell me how can i control volume with one tv remote.
leoman
how is possible to call smart tv a unit connected to internet without browser with only fix app like KDL-32WD735 ? I would like to buy a  TV unit where is pssibole to search email,address,ecc but is not possible with  KDL-32WD735 TV set.
happytony2204
I have recently purchaced my new Sony KDXE7073 and am absolutely delighted with it however, my SKY remote (Sky Q) turns the TV on, it will also change channels but unfortunately it will not alter the volume?? I dont understand how this can be. If anybody can help me with this I would be grateful.
grdavid
I have just bought a KD-55XE7002 and had it all working very quickly however the Sony SRV-HDT500 Hard Disk recorder refuses to connect via any of the HDMI connections. I have swapped cables to to avail and checked on another Sony TV that is is still working. I am just wondering if there is a compatibility issue with the new TV? Any thoughts?
profile.country.IE.title
baomaho
Just bought a KD49XE7003. hOWEVER THE SURROUND SOUND IS CAUSING A VIBRATION TO OTHER ROOMS UPSTAIRS TO SOME VERY SENSITIVE YOUNG EARS. ANY SOLUTION PLEASE
captaingwynn
can i connect my ipad or iphone to the new Bravia
LG OLED55C7V 55 Smart 4K Ultra HD HDR OLED TV
grdavid
Not physically but probably via wi-fi but I do not use Apple products so I cannot confirm.
GowenAG
I had trouble connecting to BBC IPlayer, ITV and 4 Catchup to my KD-49XE9005 TV. After advice from John Lewis Technical and Sony Technical the problem was solved eventually by BT assisting me in disconnecting Parent Control and Smart Set Up on my BT Hub 5. A very frustrating 2 days!!
JenDav1971
how can i get the itv hub app
CSA168
 Hi, I'am unable to complete my installation of my TV. The tv states no signal, everything appears ok with wi-fi. but nothing els, no channels, unable to use the remote to change find any channels.
I have a set top box.
Please advise
Thank you
misty23
I have successfully set up my new Bravia 32" WD75 and linked it via optical cable to a Goodman 60W soundbar. The results are excellent and I am delighted with the picture quality. For some reason though Freeview HD channels from 101 onwards have no sound from the soundbar, although all the other channels do. Yo can revert to TV sound but in a slimline set the sound is 'tinny' to say the least.
anrosco82
Just bought this Bravia TV KD-49XE9005 and am trying to move channels on the channel list but although the manual as instructions to do this the option in settings is greyed out. Why is this.
Heats98
It is not picking up either way.
Juddles
Please can someone take pity on a novice trying to set up her new KDL-32WD756
where do I connect my SkyQ HDMI1 cable?😱🧐🥺
stanheptinstall
If I go to MY Sony and select ITV Hub, it does not link in to ITV Hub. Its ok on BBC iplayer.
Am I doing something wrong?
