MESSAGING
TIBERIUS1
MESSAGING
How do I turn off predicted text?
1 ACCEPTED SOLUTION
Martin1
Enthusiast
Hi @TIBERIUS1, let me see if I can help out here!
As @uliwooly mentioned, enabling or disabling predicted text is done using the menus in Swiftkey. Find and tap Settings > System > Language & input > On-screen keyboard > Swiftkey keyboard > Typing > Typing & autocorrect > Disable the function named Autocorrect using the slider next to the text.
I hope that helped! Slightly_smiling_Face
10 REPLIES 10
Uliwooly
Martin1
Enthusiast
TIBERIUS1
It didn't work! 🤔
Martin1
Enthusiast
Thank you @TIBERIUS1 for your quick reply!
In that case, try going to Settings > System > Language & input > Advanced > Spell checker > Disable.
Let me know how it goes!
TIBERIUS1
job done and much appreciated!
Martin1
Enthusiast
No worries, @TIBERIUS1! I am glad that i could help!
Let me know if anything else comes up! Slightly_smiling_Face
TIBERIUS1
Sorry for pestering you again but when I send a text the phone says "sent" but the recipient never gets the message. Also I don't have a "message centre" number. AND (there's more!) I'm stuck with setting the time before a missed call gets diverted to the relevant phone thingy.
Martin1
Enthusiast
No worries, @TIBERIUS1, you are not pestering at all! Slightly_smiling_Face
As messaging center number is supposed to be provided from the SIM card, there is way to set or change the messaging center number. My suggestion is to get in contact with your service provider in order to have your SIM card replaced.
As for the other thing you mentioned, I am not really sure on what you mean, could you please elaborate?
TIBERIUS1
I meant "call divert". On my last phone I could set the phone for how long the phone would ring before it was diverted to thing where the caller could leave a voice message.
