Signal issues, only Emergency calls
Mau6
My sony xperia has no signal appears only emergency calls
Mi sony xperia no tiene señal aparese solo llamadas de emergencia
1 REPLY 1
Uliwooly
@Mau6
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Did the issue just started? if it did, could you test the SIM card with a different phone, also, if possible, test a different SIM card with your phone.
