why xperia m/dual firmware start with 15?
bang
anybody know
why the firmware numbers xperia m/dual beginning at 15 that goes beyond other smartphones firmware
but this phone release long time ago and still in 4.1
i take sample from http://www.flashtool.net/firmwares.php
XPERIA Z1 (C6902,6903,C6906,C6916,C6943)
14.2.A.0.290 Customized FR
XPERIA Z ULTRA (6833)
14.1.B.1.532 Customized FR
XPERIA SP (C5302,C5303,C5306)
12.0.A.1.257 Customized US
XPERIA Z (C6602,C6603,C6606)
10.1.1.B.0.166 T-Mobile US
XPERIA T (LT30P)
9.1.A.1.142 Customized TW
XPERIA V (LT25I)
9.1.A.1.145 Customized SG
XPERIA S (LT26I)
6.2.B.0.211 Customized MEA
XPERIA ARC S (LT18I)
4.1.B.1.13 Vodafone DE
XPERIA PLAY (R800I|X)
4.0.2.E.0.57 Verizon USA
SONYERICSSON XPERIA X10 (X10I)
3.0.1.G.0.75 Customized FR
maybe some member from xda forum can give us some answer here.
1 ACCEPTED SOLUTION
Hampus
Champion
Each phone is different projects within Sony that use different developers for the software and the hardware. If a phone have a higher build number, it does not necessarily mean that it has a newer software than other phones. Another Sony model that have a build number that starts with 15 is Xperia L, which mean that Xperia M/M dual is not alone with the build number that starts with 15.
3 REPLIES 3
Hampus
Champion
bang
roger !
but why do they use the number 15
why not lower.
but it does not matter
it is just a number
Hampus
Champion
There is no particular reason why the build number differ from the phone models. And unfortunately, I do not know why they have chosen the number 15 for these models. The only thing that you need to be aware of is if the build number for your model changes.
