Accessory unsupported for Xperia Arc S
grahammb1
I bought a replacement MH650 headset for use with my Xperia Arc S phone.  Upon attempting to use it, I get an error message: 'Accessory not supported'.  My previous headset was the same, I replaced it only because I lost it, so I can't understand where the problem lies.  Please can you help?
Thanks very much.
1 ACCEPTED SOLUTION
Rickard
Master
Then it should work so there's something wrong with the headset or phone. As
6 REPLIES 6
Uliwooly
the Xperia Arc (2010 and 2011) use OMTP standard, 2012, 2013, 2014 CTIA standard
grahammb1
Thanks, I'm afraid that I don't really understand whether that answers my question.  My headset doesn't work with the device that it's designed for.  Do you have any suggestions about what I can do to fix this issue?
Uliwooly
Now that's quite odd, you might want to take them back to the store
Rickard
Master
If you look at the label on the headset, does it say MH650 or MH650c?
grahammb1
 Thanks for responding.  It says MH650, as I stated originally. I'd checked some f the previous posts about the difference before I posted my query.  Any ideas please?  I'd really appreciate it.
Rickard
Master
