- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Call history/log is not showing up
I made a call from the call history (to a last called number) and then locked the screen from there. Then when I unlocked the screen, I am not seeing the call history atall !!! Its showing blank, I tried to restart and make calls, etc. but still the history shows empty. Anybody else faced this issue ? Any known workarounds ?
This is a big problem as call logs are very important feature for me as a basic phone itself. Please give your suggestions.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am having the same issues and dont know what to do. It can't be so complicated to show missed, dialed, received calls. All options are shown yet the phone shows only last call. frustrating
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have also an empty caller log even if have missed a call or made a call. Where is the "hidden" option, I cant find out how to get the log working so need urgent help......
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hmm if it could be so simple
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It should be if you tap the third sensitive button in call log.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Settings-apps-all-phone,force stop and clear data.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have the exact same problem with my Z1 compact. Empty call log, definitely have the 'show call log' option ticked. Restarted, took the SIM out and all that jazz. Eventually, I got a new SIM, did a factory reset, which solved the issue temporarily. Couple of hours later it went missing again! I can't be asked doing a full reset every time the phone log goes missing! Surely there must be a way to fix this? I'm tempted to get my old iPhone out
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there.
I was facing the same problem and found some kind of a solution.
I've installed a call log from Google Play (Call Log Monitor, one with a red icon) selected all the log (with the check boxes) and delete the log. On the Phone log it appears a message saying "Call log empty", tried to make a call and the call appeared on the log.
Problem solved, with a little effort.
I think that the problem is with the recover app from Sony, so... DON'T use it
Hope this post can help you all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This works for me, thanks!
