- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I disabled from the camera settings the QuickButton, as camera goes on a quite easelly from the login screen of 4.3
The end result is that I cannor get camera on. The camera button doesn't work nor I cannot find the camera app 😞
I do get camera working with the additional app but via those cannot get into original settings.
I _reallty_ would not like to reinstall the whole FW, any hints how to get access to the standard camera app ???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You are correct, the Camera application is there but with the of phone's set-up language (in my case 'Kamera'). That's why I couldn't find it amoung the others.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
There should be an app called camera,the same like you would quick launch it.From there,enable quick launch.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Under the All
There is 'Xperia camera extension' and the 'Camera Common' & 'Camera extension'
The only option seems to disable i.e. they are available
Though I found the solution! Search Application-Camera ; the Camera started and I was able to solve the problem. Still I have no Camera Icon available on the All Applications view but with camera button it starts???
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you scroll down isn't it there?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Great.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
This was the best solution and very easy too. Go to
Settings
Apps
'All' or there maybe a tab named 'Disabled'
Find the 'Camera' app and click 'Enable'.
Chances are you disabled the camera app when you were trying to make some space on your phone.
