Country code prefix problem
OPGELOST
Niet van toepassing
I am using a X10 Mini on Cosmote GR.
Incoming texts have the country code (+30) prefix.
If NOT saved in phone book with country code, the phone doesn't recognize the contacts' texts.
If saved WITH country code, the phone does not recognize the contact when calling.
Let's demonstrate the issue using an example number. +30 69 12345678  is a standard Greek mobile number.
I have my contacts stored in the following format: +30 69 xxxxxxxx but on incoming calls, the number appears as 69 xxxxxxxx and it doesn't match with the contact.
If I change the contacts to exclude the country code in front, then you have an issue with the text messages where the incoming number is identified as +30 69 xxxxxxxx inclusive of the country code - and again it doesn't match with the contact.
Thanks in advance
Panos
10 ANTWOORDEN 10
Wiko1
Bezoeker
You must be joking
Double the entries?
This is disqualifying this Phone
Any other solution
Configuration?
