Hi Team,
Please Help.
Three days back my phone was configured for outlook and on the same day the display shows EMERGENCY CALLS ONLY.
I thought that it was a sim problema and hence got my duplicate sim.
But Still the display shows emergency calls only.
Note: getting texts and calls but cant view them.
Please help i cant move to any other screen or access anything.
Regards,
Alexis
Thanks!
Hi Sam,
I'm experiencing the same problem, I tried to follow the steps suggested by Sam but support zone says that no phone is connected. I think that I need to enter a password on my screen but actually I had no password on my phone before. So what can I do?
Plz help
I am having the same problem, changed the sim, did a factory reset, did a 2 system repair, nothing works, my phone gets signal intermittently, and does not get any data, even when there is a signal.
Please help.
Phone: sony xz 8331.
Yes I did a system repair with XC and still the same problem, I have contacted a dealer in Miami to possibly have it sent and repaired. Hard to have such and expensive paper weight.
