Having prblem with (MTP)
mmahdit
after i update my Xperia Sola to andorid 4.0.4 Ice cream Sandwich
i can't open the internal storage and i just can use the MSC mode and i don't know what to do
is any way to solve this problem ???
1 ACCEPTED SOLUTION
mmahdit
5 REPLIES 5
Alexander1
Champion
Please take a look at the following FAQ topic:
http://talk.sonymobile.com/t5/FAQ/USB-connection-problems/m-p/348074#U348074
mmahdit
the prblem is still unsolved
when i connect my sola with usb cable to the computer
Sony Pc Companion shows this message
but the pc can't detect it ...
Alexander1
Champion
Strange! Have you tried different USB ports and a different USB cable?
Which Windows OS do you have on your PC?
mmahdit
Problem Solved
ABabbasi
i have tried all the steps mentioned but issue is still there. Can you please help.
Waiting for your prompt response.
