How to Root Sony Ericsson Live With Walkman (WT19i)
Good Night, I wanted to return the version of android 2.3.4 because the 4.0.4 version of ICS is having many problems for me the touch screen does not work right and I wanted to go back to version 2.3.4 please help me.
Past three months have updated to version 4.0.4 ICS started having problems in Touch Screen
Note: I have done the test of touch and what he says is working well.
1 ACCEPTED SOLUTION
6 REPLIES 6
Uliwooly
How to manually update, downgrade, root 2011 Xperias
http://talk.sonymobile.com/thread/38251
Thank you very much, so I realized I have to do manually.
Thank you for your help Slightly_smiling_Face
Uliwooly
Anytime Slightly_smiling_Face
What version do you recommend? WT19i_4.0.2.A.0.62 or 4.0.2.A.0.58 ?
Uliwooly
