Hi there,
My xperia phone appears, in windows 7, as a "portable device" or "portable media player"
So, i'm looking for a way to get my phone to appears in windows 7 as a regular USB stick with a regular drive letter (E:\ H:\ K:\)
because many SW cannot acces it (SD card or internal mem) unless i provide a standard drive access "K:\SD Card"
all i get now is : "Computer\Xperia SP\SD Card" not SW usable/reachable
Any clue?
thanks
Settings-xperia connectivity-usb connectivity-usb connection mode-MSC or MTP.
Change the usb connection mode to mass storage.
Good idea!!
but how to do it?
I've tried to enable USB debugging in the settings --> developer options, but no luck... yet
note : how to enable your "developer options" in the settings menu :
settings --> about phone --> build number
(Click 7 times on "build number" and you'll enable the "settings --> developer option"
@alexdon wrote:Settings-xperia connectivity-usb connectivity-usb connection mode-MSC or MTP.
Damm i'm dumb...
didn't bother look into settings --> xperia menu and that's it the answer!!
thanks!!
Don't worry,you are not dumb.We are here to learn things!
