Hello,
can i put cm9 rc1 of mt15i on my mt15a?what it will affect in phone?
Hi everyone:
I know this post is pretty old but I'm very interested in a response about this:
It is possible MT15i behaves as a MT15a ?
I am absolutely sure what I need in my country is MT15a band compatibility. So, if my MT15i can be flashed or formatted or something to act as a MT15a, please I need to know what should I do for that.
I am sorry if I am posting in a wrong way or site; please help me to do it right if necessary and thank you in advance for help.
Best regards,
CD
@uliwooly-wooly wrote:you are only using the firmware the 3G bands stay the same. I know that for a fact
on other Xperias so if you use MT15i software on MT15a, it will work as an MT15a
Hi uliwooly-wooly:
I write directly to you because I was looking for an explanation if my MT15i could work as a MT15a and your comment opened a little window to belive that can be true.
Please let me know if MT15i can be flashed or reinstalled or something to work with 3G/H in bands 850/1900 as MT15a does.
Thank you very much in advance.
