Dear Support,
Kindly be informed that My Telephone keep on restarting and don't know how to fix it, i try several solutions, but it didn't work until now.
i try to work on PC compinion, but it can't detect the mobile, becasue it restart.
i try flash tool ( EMma) but it can't detect the mobile too.
i try to use hard reset & safe mood ( Power button + Volume down) & ( Power button + Home & Menue) but nothing happened.
would you please advsie how to fix it, it's urgent to know this solution, because i need it
Note: i don't need the data on the mobile, i need the mobile to work.
Best Regards,
Hisham Abd EL Hamied
E-Mail:
hi. I have the same problem my mobile keeps on rebooting. tried pc ompanion but it says no software available for my mobile. sony xperia LT15i
Worked for me:)
Thank you very much...
what was it that worked for you adrian14 ?
I HAVE THIS PROBLEM TOO, BUT am cautious about fixing it
@Czlomax wrote:Just turn OFF bluetooth... and then it will be OK
But you must be quick
Yes my device started rebooting after l had turned Bluetooth on butl only see a black screen and then reboots
