I think you should visit a sony service:
http://www.sonymobile.com/global-en/support/contact-us/
hey diver, I am facing the same issue.. its restarting in a loop after installing and applying the update of winter theme on 4.3.
the sony companion cannot detect it as it keeps restarting, the update service is recognizing the device (power+vol down) but is saying it is up to date and just EXIT. Installed flasher tool, it is also of no use. Downloaded Emma flasher tool but waiting for verification, also not sure whether Emma supports Xperia V as the support page doesn't have its name.
I am from india and got this phone from Dubai and I dont know whether sony india support center will be able to solve it or not.
There are so many experienced guys on flashing here, Please HELP!!!
try to connect while your phone is off
i also have the same problem. and even can't force shutdown. how to repair directly?
Hi Guys
Yes even i had faced the same issue on my XPERIA SP once i installed the winter theme it kept on Auto restarting..
I removed my SD card & SIM Card and allowed it to restart atleast more than 15times and then it took me to the home screens and then immediately I changed my theme to a default one and uninstalled the winter from the APP settings.
Please Note: DO NOT try to LOCK/UNLOCK your device once its on the home screen, otherwise it will start restarting again.Immediately change the theme.
But its very sure that the problem occured after installing the winter theme.. So would request XPeria Support team to fix the bug.
Hope this helps... Or else HArd rest your xperia phone to factory settings.
Vinay
hi , i also recieved the same problem , i install sony update service but there is no xperia v option in the program , so how about do i do this?
You need to run it in compatibility mode with windows 7.
then xperia v is working normal? dnitin
If you run SUS in compatibility mode with windows 7,you can select Xperia V and repair.I hope that this will help.
