SIr, i've tried so many times by completing requirement of defocusiing. I put object around 30 cms from background and wait for almost 5-7 min with steady hand to blur the background, but still cant defocus background.
Gelöst! Gehe zu Lösung.
beckground defoucs by me ... actually i must say sorry to sony for all these blasphamy
.. n coardially thankz fo this app..
for those who want to get the result ...
first of all u have to know that it captures TINY images first and defocus it properly so my advice is to put finger in that "SQUARE" ( when it says you to touch the area you want to focus) as i'hve shown in last image ( put finger very close to camera lense )... when you put it would defocus in no time ... ( if not then try to move finger very slowly away from camera lense and see whether it defocus or not )
in my other images background is almost 4-6 feet away and that DEO bottle if very close to lense ....
my another advice is that please do not put OBJECT ( you want to focus ) on groundflor .. becouse it would be hard for camera to diffrentiate between background and ground flor ...
but still i can not defocus a background while capturing picture of PERSON ...
but it feels good after capturing it ..
its all about practice
but how much time i shoud be steady.. ?? it doesnt even defocus a bit ... any standerd procedure for that ???
You have to tap on the screen first on the object you want,after that you can take the shot.
actually sir i tap on object and when i try to capture it it shows mesage that " could not blur background" .. i tried even through physical camera button ...
It happened to me first time I tried it (on Z1) but now it works great.
background must have at least 2-3 foot distance from your object or background must have same depth
otherwise it wont defocus or just a little of background got defocus
i think sony should include tutorial instead of written instruction .. bcz its not a normal camera app ... Look at the google camera, users can easyly do BG defocus. Even in Z series its easy to use this app ...
