Problem in transfer of photos from phone to laptop ( photos not showing in memory card folder)
nikhilaries
I'm new user to Sony and find it amusing that photos which are showing in gallery section are not showing in memory card DCIM folder when i connect my phone to laptop. i checked all settings but could not found out what is the problem why the photos are not showing.
please help me and advise how to sort out this problem./
thanks!
13 REPLIES 13
profile.country.PH.title
MarlonUk1
have you tried connecting the sd card using a memory card reader instead of connecting it via the phone?
MarlonUk1
or try to sync your phone using Media GO,
cytheriamiller
You need a USB cable compatible with your PC and phone. Plug in the cable to your phone and PC. Then, go on your phone and open Settings. Then, find Connect to PC and choose the default as "Mount as Disk Drive" or "Disk Drive". This will then mount your phone's internal storage and SD Card is disk drives on your computer, which will allow you to search for photos and copy them.
isabelscott
I usually transfer various files with USB cable. Especially, I love to take photos with my Galaxy S4 and then transfer them to my PC for backing up.
But if your computer didn't see your photos, you can attach to an email and open on your PC.
Wanna know more tricks on how to transfer photo from Android to PC, please click the link and learn more method. One is use Android Manager.
