Se ha detenido el proceso com.google.process.gapps"
se ha detenido el proceso android.process.acore
I'm trying to restore from factory, but have an hour or more erasing information, but do not think it is doing.
Thanks for nothing, I found the solution myself. And the solution was to format the phone with the program SUS
The result was worse after the restoration, now the application to make calls also stops.
sonyericsson.provider.voipcalllog has stopped
