By mistake, I seleted "call from phone" as my default dialer. I want it to reset it so i can select from diffrent dailers while calling. I dont want to reset my phn to factory settings, so any suggestion other than that will be apriciated.
actually, i want that whenever i dail a number, it should ask me which software to use..Usualy i have to call in diffrent countries and thus i use Mobile VOIP.. but now if i have to call someone, i have to open the software and i have to dial from that.. one more problem is MVOIP doesnt store the recent dialed numbers unless it is dialed from general call dialer..
Have you tried looking in settings-apps-all for mvoip and clear defaults for it?
It seems that you might need to reset to factory settings.I am sorry to say this.
