Hi! I have strange problem over here! Sony Update Service downgraded my Xperia V software from JB 4.3 (9.2.A.0.295) to 4.1.2 (9.1.A.1.140)... I checked SUS hoping that my Xperia V will get JB 4.3 (9.2.A.1.199) and SUS said that new software is available, i upgraded and BAM! Now i have JB 4.1.2 (9.1.A.1.140)... Anyone got this problem? Or i'm just so unlucky..?
I think I'm having the same problem. I bought the phone two days ago and updated the system. Now I have 4.1.2 and the update service says that there are no updates for my system.
I will try now to update through the computer.
Does anybody knows more about this issue.If Sony stoped the updates, there should be an announcement of that decission.
No luck with the pc upgrade. The current version is 4.1.2 but the computer says that it is up to date.
Any help?
Hey there. The same thing happened to me, and after the phone was in the shop for a fix because 4.3 was buggy and made it force restart. They did their own update and it reverted the software...I did it again on my own, companion said that new software was available - and yet again installed 4.1.2, as it turned out. It would have been very disapointing if the 4.3 had worked. This way..who knows :). Any advice?
