Good morning everyone!
I would like ask for help. Yesterday I bought myself a SONY LED 40W600B. I know it's an Internet TV and capable of doing Screen Mirroring. I also own a T2 Ultra and loving it each day.
However, I was so upset finding out it could not establish a screen mirroring with my new TV. Tried lots and lots of tips given from some resources over the internet for hours but never found a solution.
I was wondering if someone here had the same problem before and was able to fix it.
Here is what I did last night:
1. Turned ON both devices
2. Went to Screen Mirroring on TV
3. Went to Setting-Xperia Connectivity-Screen Mirroring. I found my Bravia on the list then tap it.
4. It was written on TV that they're trying to connect (forgot the exact sentence)
5. Within 3-4 seconds, My phone stopped doing the process with a notification: "Mirroring Session ended. Screen Mirroring turn off."
My Xperia is T2 Ultra running 4.4.3 Kernel 3.4.0+ Build Number 19.1.1A.0.165
So far I know nothing bout my TV, i just bought last night and DID choose Automatic Update when doing Auto-Startup process in the beginning.
Please help me, as need it badly to screen mirror my Xperia. Thanks so much in advance.
have you connect both TV and Phone to the same Network or WIFI ?
I tried that, too.. Still didn't fix the problem.. No difference.
However, I heard that you dont reeally need to do that since the connection is considered WIFI direct connection.
Download a WiFI direct app and try again
@uliwooly Tried that, too. WIFI Direct is connected but CAN'T DO anything else other than that. I tried to screen mirror after...the WIFI direct turned off automatically and I still cant screen mirror (same error message)
@phy My devices are both capable of doing screen mirror. My TV is 40W600B Internet LED TV. My phone is Xperia T2 Ultra, with screen mirroring feature.
I have followed what was instructed in userguide. It doesnt seem to work
I'm getting more and more pesimistic.. Maybe its a defect TV?? But the WIFI works perfectly....
Are both using the same wifi connection? (tv and phone)?
https://docs.sony.com/release/KDL-48W600B_40W600B_BRAVIA_i-Manual_EN.pdf
Click on Using Home Network
