I have just bought Sony Xperia SP in India.
I have installed few apps and games on the phone.
I wish to transfer these apps and games on SD card however there is no provision of moving the same from Phone memory to SD card. The only option I could see was transfer to photos/ music & Videos.
Could you please suggest any option for moving the games & apps from Phone's Internal memory to SD card (a feature which is available in Xperia Neo).
I tried using few apps available on play store like App2SD etc however I was unable to move the games & apps to SD card.
Would appreciate your solution on the above.
Regards,
Ajay
I think it's not possible, this question has been already discussed. see links below
http://talk.sonymobile.com/t5/Xperia-SP/Transfer-of-App-from-Phone-Memory-to-SD-Car/m-p/314684
http://talk.sonymobile.com/t5/FAQ/Memory-in-Android-devices/m-p/348064
I have Xperia SP, but I can not move the application to the SD card.
Do you became I could transfer the applications to SD card when I receive the update 4.3?
When will my phone receive the update 4.3 ?
For now,no 4.3 update will make apps to sd possible.
Has new update for xperia sp (android 4.3), solved the problem or added the feature of transferring installed apps/games to sd card ?? 8gb is running out.
Nope...there is no app transfer option
Just, when will Sony fix this issue.
It seems for now,that will not be available.You can go on and root your phone to get it,but this might void your warranty.
Can u brief me the procedures.......... Or any app available to do such stuff ..
