Ussd code running while calling
34
hi i get a problem when making a call.when i want to make a call it shows "USSD CODE IS RUNNING" with the call page on the screen.but it calls to that person and shows this message all the time until i press ok.what should i do?my phone has a problem or my card? and my android version is 4.1.please answer.it's emergency
Tags (1)
3 REPLIES 3
Thommo
There are apps out there which can infect android devices and these apps can run USSD codes and be able to do many things mainly wipe devices or send info to someone somewhere - or you have stolen or found the device and the owner is tracking it - So for this reason I find myself unwilling to help much more as I can not confirm you are the correct owner of the device - If you are I apologise but for now I will point you towards Xperia care http://www.sonymobile.com/global-en/support/contact-us/ or visit the place of purchase
RakeshNohria
Just restart your phone and problem will be solved.. Slightly_smiling_Face
Ralph2006
How do I turn off
