annulla
Cerca invece
Intendevi dire:
What's difference between LT28i and LT28h ?
RISOLTO
cyberpic
Visitatore
I've got the LT28h and I would like to know if there 's hardware or software difference.
1 SOLUZIONE ACCETTATA
Soluzioni accettate
Dr_Chris
Campione
Yes there is a hardware difference as the LT28h, also known as the Xperia Ion HSPA, is a GSM/3G phone, whereas the LT28i, also known as the Xperia Ion LTE, is a 4G phone, in addition to being a GSM/3G phone.
8 RISPOSTE 8
Dr_Chris
Campione
cyberpic
Visitatore
Thanx
Dr_Chris
Campione
No worries.
laaivayta101588
Visitatore
So, I heard that the LT28h has sensme, new Walkman version, Xcloud, Clearbass..... that the LT28i doesn't have. Does the LT28i have those thing when I update it from Android 2.3 to Android 4.0?
toannguyen92
Visitatore
I mean how to know it not just tell that cause it is well known that the lt28i is LTE/4g version and the lt28h is HSPA/3G version. I recently buy one but not sure how to check this too and still looking for the answer( if the firmware is not stock maybe it not show that information??- xda-developers)
tonynmisty
Visitatore
what about lt28at? is that the at&t model? what's the difference?
aks81
Visitatore
It is same as LT28i. Just branded for at&t with some carrier customizations(read bloatware)
lingmaaki
Visitatore
There is a hardware difference as the LT28h, also known as the Xperia Ion HSPA, is a GSM/3G phone, where as the LT28i, also known as the Xperia Ion LTE, is a 4G phone, in addition to being a GSM/3G phone. Also, Lt28i would provide better mobile signals and faster internet data speeds as it supports 4G. Go for that.
