which pendrive brand/model works with xperia u with usb otg cable
drone
Hi guys i bought a usb otg cable for my xperia u and i have successfully connected a mouse and an old 1 gb pendrive (i dont know the brand) with it.
So I ordered an 8 gb Transcend Jetflash 300 pendrive for it but it is giving me a power consumption error on the phone.
If anyone has tried a 4gb or 8gb pendrive that actually works with the phone can you tell me the model and brand of the pendrive.
1 ACCEPTED SOLUTION
ashisharia
sure, i too bought it and it works awesome..super fast/never hangs..i have Sandisk Cruzer 16 GB so i found it strange a lot that how cant a 8gb is giving error which 16 gb is being run fast.. i would advice all to buy this only as its cheapest n dont have led which consumes power uselessly...
10 REPLIES 10
ashisharia
sfrskz
you must try kingston. transcend don t work.
this model  work surely
http://www.onderkirtasiye.com/uploads/urun/kingston_4gb.jpg
RehanManUtd
Will Sandisk 8gb Cruzer Work On The Xperia U?? I'm Planning On Buying That!
WillWord
I use Scandisk cruser blade 16GB no problems
sushil_naik
Yes it does support the Transcend jet flash 500 16gb pendrive
Preacher_U
Same for me, some sticks do not work, Sandisk cruzer works fine.
As I found it very useful, I bought one of these:
http://dx.com/p/c310-otg-tf-card-reader-w-usb-to-micro-usb-adapter-for-samsung-i9100-i9300-i9220-n71...
BUT - it only works with Samsung phones, tried it successfully on friends' S2 and S3, not worling on Galaxy Nexus and also not on my XPU - this one supposes to be connected to a computer and shows that it starts "charging" 🙂
tonytomson
HP v218g(16GB) and Strontium Bold 32GB wont work...I lost my money....Any other model than cruzer blade?
PsillyPseudonym
I bought a 32GB SanDisk Fit which works fine with my Xperia U.
