Hello friends,
I have updated my phone to JB 6.2.B.1.96... After updating issues present in previous update were solved but now i'm facing new problem as mentioned below,
1. swiftkey keyboard automaticaly hides itself from typing only in WhatsApp also copy-paste texts sometime
2. While playing game hill climb racing it automatilcally tryies to escape from game like we press back button
3. i noticed that sometime my wifi turn on automatically
Does any budy having this kind of problem? Please help e to solve...
If you recently updated,something could went wrong with the install.You can reset to factory settings,phone will improve.
for my acro s also same wifi issue after its 6.2.B.1.96 upgrade...then may be its a bug...
Thanks... at first look issue regarding auto refreshing screen is solved.... played game without interference...
Nice to hear that.Do not forget to give kudos.
Now, Having problem with HDMI... when connecting with TV, it automatically disables volume. I have to remove and reconnect cable everytime.
Secondly, problem with camara button on locked screen, when using, it automatically clicks picture without aiming...
Try to clear data for HDMI in settings-apps-all.
After update I am facing a problem at Wi-Fi connection. when I try to connect at Wi-Fi it shows Obtaining IP address....
Can any one help me to fix this problem...
Hello
after update my Xperia SL to JB , wifi had a problem in connection to any network and reset to factory settings not useful
can you download update with solution for this problem?
I am very upset with this problem
, although I love the Sony devices
, but this problem too disturbing
can you solve it please
thanks for you
