Xperia S Problem
ROZWIĄZANE
skyliner34rb26
Początkujący
Xperia S Problem
my xperia s is aways pausing for itself when i play a heavy game like modern combat 4 how to fix? it was only doing that today i got the phone on the 28th december please reply
18 ODPOW. 18
skyliner34rb26
Początkujący
ok i disabled them i am testing the phone now
Uliwooly
if that doesn't work then > uninstall them > restart your phone > try again
skyliner34rb26
Początkujący
ok right now it works great again thanks ! i'll write back if i get any more bugs
Uliwooly
cool, most of the time the issues are related to other intrusive and/or poor coded apps.
arun19pedapudi
Początkujący
Uliwooly,
im using AVG antivirus software in my Xsl.other than this im nt using any task killers etc.should I uninstall the antivirus.is there any problem without having antivirus.
Sorry for my poor english.thanks in advance
Uliwooly
I would suggest that you uninstall it, you don't need antivirus, this isn't PC Dizzy_Face
there aren't any virus on Android, also if you donwnload apps from the play store you should be ok.
gulllgi
Początkujący
Not working
مجید
Początkujący
I can not turn my phone off and did not advance the flashing arrows marked corrupted repairman told her the boot device only sound comes Connectivity Standby light turns red, please help me
PoopPoop543
Początkujący
Im rooted and MC4 does it should i install a ram booster
