Xperia SL Wifi IP Address Unavailable
volkantokuc
Since the 4th of July (in version 6.2.B.0.200), I can not connect to any wifi networks.(I live in Turkey) It searches and can not FIND any networks. After certain advanced settings trials (static IP etc.), flight mode and ejection of SIM card, no security in my home router, upgrade to 6.2.B.0.211 via Sony Update Service with full factory reset, it barely finds my home network but finally just says SAVED and SECURED with WPA(WPA2, it does not differ) but no connection and no wifi bar in the notification bar.
Today, I figured out that in the advanced settings of WIFI menu, IP Address section mentions "Unavailable" even if the wifi is open.
Is there any way to resolve this issue?
5 REPLIES 5
Uliwooly
there are other threads on the same topic, use the Search bar (top right) to look for answers and/or suggestions
volkantokuc
Thanks for your directions and how to use the forum guidance however I could not find any topic or helping ANSWER covering or including IP Unavailable issue during these 24 days. Just answers keep suggesting repairing the phone via SUS and these are really not helping because I tried it three times. So unfortunately I opened a new thread and I apologize for my huge mistake. If somebody can help me I will appreciate that.
nhunter
I to am having this problem on an Xperia S (LT26i). I have read many, and I mean MANY posts to this forum and others of this being a VERY common problem and still there is no fix. I did take the advice and my phone went to a repair centre and it came back and I was told that it was irrepairable and would cost more than the phone!! I had only had it for 7 months!! Tied to a contract and had an expensive brick!!
So I have SUS'd it, downgraded it and got the wireless to work only to start using the phone again and it stop working again.
I have got to say that I moved from an iPhone 3GS to what I thought was a decent phone (Sony) and a tried and tested OS. I actually wish that I had never wasted my money and stayed with IOS and Apple. I didn't have a single issue in the 3 years with that phone.
I have subsequently upgraded to the newest Jelly Bean after several other software and OS changes. I got the phone WIFI working again (no hardware replacing, no costly repair)!!!! However again after several days the WIFI will not connect to any 'known' SSID's which is complete crap.
Also WIFI will not turn on unless I do a hard reset (hold power and up volume key and wait for the 3 vibrates). Turn it back on, take out the SIM (the Xperia reboots), then put the SIM back in (the Xperia reboots again) and then WIFI turns on and operates for a day. Then STOPS.....
Just to add I do not have any AV or app running my wireless connections. I have SUS'd, upgraded, downgraded, flashed, factory reset the device so many times that it is pretty much first time boot other than turning off touch tones.
This has to be a software, driver or other issue rather than hardware!!!! If it was hardware it would just NOT WORK. There are also SO many owners of Xperia S devices having this exact same problem/issue that I cannot believe that Sony has an inherent hardware component issue in all the phones.
Has anyone found a way to reslove these issues or is Sony actually listening and trying to resolve them themselves????
RONITH
SAME PROBLEM PLS FIND SOLUTION SOON????
Nicemom-2
My Xperia tablet says ip address unknown. I am unable to connect to WiFi could this be the problem
