Hi, i've got couple of problems after updating to 4.3,they are listed below:
1.when I'm working with 2 or 3 apps(like: walkman,and email or any thing else) battery gets really hot
2.sometime it hangs for a few seconds
3.ram used to be free around 245 but after updating it is just 186 or even less
4.sometimes touch doesn't work for pattern and I have to redraw it
are they normal and will fix or i have to downgrade to previous version?
thnak you
DO NOT use this kind of apps..they consume ram and will cause problems..
You have stamania mode that extend your battery life..so no need to battery saver
Also you can force stop and clean data and Cache for any apps you want..so no need to clean mater
hi
did you perform reset to factory after update?in most cases it solved ram issue(like mine)
its normal that battery overheat after update..you will face it for some days..it will be fixed
yes, I did. but after installing my apps ram gets low again, do you think it will solve this issue if I reset again?(I did it two times before)
and thank you for battery problem
If you do this already so I dont think need another time..do you use task killer battery saver or something like this??
Also keep in mind that apps like Facebook viber line etc... Will consume more rame
You are welcome
yes, i use battery doctor, battery Guru and clean master at the same time. do you think they are too many to use? if so, what do you suggest as the best one?
thank you so much
You are welcome
Good to hear that...mine also performing well
