Hello. I couldn0t find any post with similiar problems.
I installed theme on my xperia. After that it shuts down, but not as usually. There goes SONY screen, XPERIA screen, colorful waves (or whatever it is called) than it freezes, and running that three things ALL OVER AGAIN ONLY.
I tried holding those buttons (volume up + power), but nothing - it turns off and when i try to turn it on, that keeps happening again. I tried connecting to computer, but nothing - he doesnt turn up, so keeps conncecting and discnnecting after 1 second - I cant do anything with that option. I can charge it although, but that doesnt help me, right?
WHAT TO DO NOW
help please..
Try performing a system repair using Pc Companion as this will often fix issues - This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
I did. Won't help
Thank you for advice, I tried that earlier but I didn't see that in BLUE.
I fixed it.
THANK YOU SO MUCH again!
Use my above guide and if that fails then you need to either return your device to the place of purchase or contact Xperia care http://www.sonymobile.com/global-en/support/contact-us/
