hdmi problem
Lorrie67
hdmi problem
Hey folks,
I'm hoping some an can help me🙏🏼
I have a Jodi box but when I plug it into any
of the hdmi ports the colour changes,
it changes to a greedy blue colour then switches back.
my free view box works but that in the scratch socket.
Thanz in advance guys 💋
3 REPLIES 3
Not applicable
Hi there
I am assuming that you are referring to a Kodi media player connect to the TV via HDMI - which gives you a greeny blue colour on the screen?  However your freeview box works fine connected to the SCART socket.
First thing is to use another HDMI cable as a test.
Also, have a look at this guide:
https://community.sony.co.uk/t5/android-tv/hdmi-problems-troubleshooting-steps/td-p/2141941
However to be honest, more specific information is required:
  • Model of TV
  • Make/Model of Kodi box
Lorrie67
Hello, yes I have tried different cable and hdmi port, but colour still changing. I have a Sony Bravia KDL-32BX300 Tv, and a nexbox A95X android box. Any more help would be gratefully appreciated. Tia.
Not applicable
Hi there
I have done a bit of research into this, but it appears that its the Nexbox A95X where the issue lies.
Links:
https://disqus.com/home/channel/nexbox/discussion/channel-nexbox/a95x_pinkgreen_output_image_glitch/
https://disqus.com/home/channel/nexbox/discussion/channel-nexbox/nexbox_a95x_s905_1gb8gb/
http://www.tvboxforum.com/showthread.php?tid=42&page=5
There is much discussion about a firmware patch for this A95X - however I cannot find concrete proof that it fixes it.  I suggest contacting support for Nexbox and find out whats going on.
Just so you know, if you type this into google, it comes up with loads of results : nexbox A95X pink green
