- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
June 2019
June 2019
Remote unreliable
Bravia TV KDL-32W4000
The remote (RM-EDO11) only works intermitently. I have put in new batteries and cleaned the battery contacts. The TV works fine using the buttons on top of the set.
What else can I check?
If all else fails please recommend a replacement remote
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2019
June 2019
@gardner.crawley wrote:Bravia TV KDL-32W4000
Hi @gardner.crawley A simple google search for Sony RM-EDO11 should yield plenty of results. Replacement remotes are extremely cheap £5-£10 or even genuine used RM-EDO11 remotes are less than £15.
