Hey everyone,
I’m at a bit of a desperate point. I want to wall mount my 2014 Sony Bravia on a modern mount that allows for screen movement and tilt etc.
I cannot for the life of me find a suitable adapter that will allow me to do it via a VESA mount, given the TV appears to be none VESA compatible.
I read online I’d need a MonLines V100B adapter but I can’t find these in the UK nor can I get one shipped to the UK.
Im sure there is a way, but I’ve just not found it so coming to the community for some help!!
Thank you!!
Hi @Dark-Wedge
I would imagine that the correct adaptor is no longer available. Sony SUWA1
One on eBay https://www.ebay.co.uk/itm/267357431169
You could try the VESA adaptor kits readily available on Amazon. Below is just one example that quotes suitable for the W8. https://www.amazon.co.uk/Part-Bracket-Adaptor-Fixing-Bravia/dp/B0195EFKGU/ref=sr_1_1
Wall mounting - What are the VESA dimensions of my TV (2009-2016 models) | Sony UK
