Can anyone help please,
I have a KDL32EX723 tv, all was well until it required a re-tune, due to the channel numbers changing. I ran the auto digital retune, it took 30 minutes to complete, it looks like it tuned into two transmitters, when I switch to BBC1 a message comes up that this program is in HD on channel 903, there is no signal on 903, I tried deleting 903 but the message still appears.
Can you select which transmitter to tune into ?.
I have the channel numbers I need, ch53 - ch60 - ch57 - ch50 - ch59 - ch55, for my transmitter, so I thought I would try a Manuel tune, but the guides only point to where the Manuel is, not how to do it.
As there are so many channels, can I clear them before starting again, (how do I do this) and how do I carry out a Manuel tune if I need to ?
Thank You for your help
Rob476
Hi, I've got an Ex723 Model to, i had similar problem, after retuning the tv. I had to reset the tv to Factory setting.
