White Pixels around outside of display KD-49XG7093
MadScot1320
I have a KD-49XG7093 Bravia TV that is only just 13 months old.
Now I have noticed that all around the edge of the display there are white pixels, especially noticeable on dark pictures. From a distance it looks like a white line, however close up it is an uneven “line” of broken pixels.
I believe that this may have started happening after I updated the software a couple of months ago. The version would the the one before the latest one.
Anyone any ideas?
1 REPLY 1
Joe_Dohn
Specialist
Make sure you're currently on the latest version, then try the basics of disconnecting everything from the TV and unplugging it from the power for ~3mins and see if you can still see this line. If you can, try factory resetting it, then just chat up Sony in case it's hardware related.
