Hello. I have a Vaio laptop which I'm trying to pair/connect via Bluetooth with my iPhone 4. I keep getting a message saying "Bluetooth Peripheral Device driver is missing" and I can't find anywhere to download one that will work. All suggestions gratefully received. Thanks. Brad
Hi Brad,
to be honest I'm not sure if mine worked correct the first time as I removed the device a few times to ensure I gave you the correct details..
You could try deleting your iPhone from your Vaio's Bluetooth devices & your vaio from your iPhone bluetooth devices, once done try repeating the pairing process again..:smileyconfused:
The iphone I used is running iOS version 6..
Im having the same problem with a Xperia phone and my viao. The peripheral bluetooth driver is missing, error code 28, cant update driver, none installed. Does anyone know where the driver can be located? there is a range of drivers when you select 'manual update/install driver' from 'browse on computer' then 'let me pick' options however I dont know where or under what; blutooth radio, bluetooth vertual devices etc, the missing one is. Any help would be greatly appreciated
I can no longer use bluetooth on my vaio and it says it's thebluetooth peripheral device. It used to be fine - is it possible that it has been accidentally deleted?
