- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
WH-1000XM4 cannot connect to two devices (2nd and 4th generation iPad Pros) simultaneously
I’ve just got these and I need to connect them to a 2nd and 4th generation iPad Pro simultaneously (both iPads are running iPadOS 14.1). My old defunct Bose cans could do this and I really expected a pair I’ve just thrown £355 down on to also be able to.
I have downloaded the app (which isn’t optimised for iPad screen sizes) and there is clearly an option to do this but, when I switch it on, it switches back off again after a couple of seconds. Is the second screenshot the reason…? If this isn’t possible, then I’m going to have to return them. What does that message mean - and is it the reason I cannot switch connection sharing on…? My old Bose cans connected to both my iPads via settings no problem. Any help, folks…?
Won’t stay switched on
Is this the reason…?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You cannot listen to both iPads simultaneously. You can only listen to one or the other.
See also: https://community.sony.de/t5/how-tos-faqs-audio/multipoint-connection/ba-p/3710909
