How to switch on/off Retail Demo app on Tablet Z ?
Does this work?
*#*#73556673#*#*
I am sorry,take the phone back.
In order to stop de the demo mode you have to chanche the password of the tablet to. Otherwise it wil install itself.
I just did it and so far its not coming back in the "running apps".
After the code change you can stop the demo in the app list ( options --> apps.)
STOP!!! Dit not work.... instaled itself after pulling out the powersupply.
the code doesnt always work so then in that case you have to rooth youre phone the easest way to do that then instal super user from appstore and a app remover sofware thats specialy designed for root there you can remoce the retail store app and retail demo app then you unroot again and you finished
The old way with root and remove doesn't work anymore in Kitkat.
Would a (Sony) shop not getting this information to change this?
These tablets are not for presentation only?
Thank you so much.. I use sony xperia Z Ultra and it works for me.. i done deactivate it and stop the retail demo video and the stop it from reset my phone.. God Bless you..
