About battery sony x
Khai2
Hai guy I just want to some thing. Can I used the battery of Sony xperia x performance with 2700 mah for my Sony Xperia X?
2 REPLIES 2
Uliwooly
@Khai2
not a wise idea, plus it might not fit
Jonas
Master
Hi @Khai2!
I don't know the exact size of the battery, but I would not recommend trying to replace a battery in a device with a battery that is made for a different model.
If you have an Xperia X and you want to replace the battery, make sure it's a battery for an Xperia X, not an Xperia X Performance or some other model.
