Intermittent sound with google maps navigation app
johngal
15 REPLIES 15
nathanhorner
I it's definitely not right that it happens but I cannot test anything as my car doesn't have bluetooth.
Hope it works out soon.
johngal
I tried playing a video it didn't have any sound either it's definitely something to do with Bluetooth linked to the car. Again is this normal? I woykd like to  think I can have my phone  linked via Bluetooth and use my GPS for navigation.
johngal
Hi thanks  again.  I've got it working in my car now it  is going through the car  audio not the  phone.my car now shows the Bluetooth sign as  well as the phone connection sign.  That'll do for me. Thanks  for all the input
nathanhorner
Thanks for taking the time to come back and share what worked, doing that really helps others.
Carlo67
Ho lo stesso problema
Non ho capito come hai risolto
I have the same problem
I didn't understand how you solved it
gt
Bobbabe
On my Subaru, I use the USB connection and Apple Car Play for Google maps. I also keep Bluetooth running. Is that ok or should I kiddy use the usb for all phone and navigation purposes?
