Is There a Setting for Limiting the Charging Current of My Xperia X?
spaceman5
Hi
My Xperia X came with a 1500mA AC Adapter, for charging.
I ould like to charge my phone much slowlier - using 500mA insteaed of 1500mA.
Does Xperia X have some setting that I can change, to make it charge slowlier, using 500mA current?
Thank you
2 REPLIES 2
profile.country.PH.title
MarlonUk1
unfortunately no. but if the battery care is activated in your device, it usually slows down the charging around 90%. this usually happens if you charge your device regularly at the same time.
or as suggested. try to use a usb cable prob. with usb 2.0 below specs
profile.country.NL.title
Strampke
You can charge from your computer's USB port
I took this from a Google search.
The USB 1.x and 2.0 specifications provide a 5 V supply on a single wire to power connected USB devices.
A unit load is defined as 100 mA in USB 2.0, and 150 mA in USB 3.0. A device may draw a maximum of 5 unit loads (500 mA) from a port in USB 2.0; 6 (900 mA) in USB 3.0.
