Hey I have a fairly wrecked Xperia x.. Before it was wrecked my beats stopped working on it. But worked on other devices, and cheaper headphones worked on my phone, the microphone is broken too so I have been using the headphones that came with it to make calls.., now they've stopped working and no head phones will work with the jack.
I know, I need a new phone.. Just something I can't afford right now. Is there any way of trying to update the jack.. It was workin up until yesterday 😕 pleaaaase.. I'm cracking up without music 😭😭😭😭
You can go to your nearest Sony center, and buy a 3.5mm headphone jack for your Xperia X. And if you know how to open your device, you can do it on your own. Everything is cheaper than buying a new device. Finally, you can just buy a bluetooth headset, and you can listen your music wirelessy.
@BrolasBrolasis right.
A nice set of BT noise canceling earphones will make you happy ever after.
On youtube you can see videos with instruction on how to repair.
I would stick by @BrolasBrolas 's advice.
