I am not able use any otg or USB devices on my xperia!
I don't understand why?
And what's wrong?
My phone has no problem charging.
I figured it out. I think the otg with days has become loose. It needs a push to work so I stopped using the otg. I think of going down to the service center and ask for a new charging port!
Did you try a restart?
Did you try it in safe mode?
Did you try to change the settings for USB connection mode?
Yes but nothing seems to work! Nothing!
That's a pity.
Did you try another connection cable too?
Did you try the same connection on another phone?
Ha! Nice you found the cause!
I have seen problems with the USB port of Xperia X several times on different forums.
Would you be so kind to mark your own answer as a solution so others can learn from it?
Hello
My phone is Z3+.
Since updating my phone to Android 7, OTG does not work, while it worked well on Android 6.
I'm surprised that many Sony users have posed the problem of OTG, but Sony does not care. I'm very sad about Sony's behavior and I do not like to leave Sony out of the future. If Sony does not care about us, we'll leave Sony too.
Thanks.
