Hello guys!
I have the problem, that my telephone only shows a white triangle instead of signal strength and the cellular radio power is off in the phone options.
I figured out it has to be because of a broken antenna part or the Sim Slot.
But i cant seem to find any replacement parts for the F5321. Is there any way to replace to "signal board receiver or sth like that"?
cheers
The name of our Sony Xperia X is F5121 or F5122 for the dual sim version. I think that you dont find any results, because you write the model incorrectly.
No, i certainly did not name to incorrect model.
I am speaking of the Xperia X Compact F5321.
There's a video on YouTube.
If not for your device then for Xperia X
That firm does sell the past you're looking for.
