Something has happened in the last day or so and now whenever i choose the help topic under the 3 dots the language is swedish instead of english ?
everything else is ok,menus, keyboard etc all english as before.. what's happened ??
I've got 20GB spare on my SD card and it still doesn't give me the option.
Where is google servers anyway..because before you risk doing a reset you'd want to peak into the data backup file to make sure everything you want to keep is there, wouldn't you ? I certainly would just 'assume' ..
tbh, it's all a mish mash...so far i've been told to use backup and restore on my phone, then PC companion, then Xperia companion...all I want is to get rid of the swedish help files ...
What's missing I think is the ability the store/backup everything to onedrive, because you can actually see what you;ve got there...and then a facility to download it all after a reset ..?
I'm losing heart tbh ..
I also use Contacts+ for my address file ..would that be included in the backup?
yes you're right - i do use help but not often enough to warrant major surgery to my phone...if there was a quick fix i'd do it, which is basically what I was hoping for. However I have loaded xperia companion and pccompanion and done a complete backup to my laptop - it'll take about 25 minutes...and it does have my contacts in there. No idea how i'd restore but I'm sure it will, if needed.
Update -
this has just fixed itself ..now back to English ...
thanks for the contributions
